greggibson
#1 Posted : Thursday, June 25, 2020 5:40:45 AM(UTC)
greggibson
Was thanked: 25 time(s) in 17 post(s)
If implementing VST3 plug-ins on vMixCallers what is the best practice? Should I apply the plugin to the bus those callers are using or to the individual vMixCall audio inputs? I am specifically referencing plugins like Vocal Rider that dynamically adjusts audio output and noise reduction plugins like NS1 and Izotope RX7? I am thinking NR should be applied to each individual input as noise can vary on each caller but is something like Vocal Rider best applied to a bus or even to Master?
Thanks,
greg
Follow Your Bliss Media
#2 Posted : Saturday, August 22, 2020 2:53:10 AM(UTC)
I'm also interested in this. I'm looking to purchase some VST plugins from Waves Audio like the Vocal Rider and Compressor or Noise Reducer. I'm not sure which plugins I should get other than the Vocal Rider, and how best to implement them in vMix. If anyone has some feedback on this it would be much appreciated.
desmar
#3 Posted : Saturday, August 22, 2020 7:01:10 AM(UTC)
desmar
Canada
I would use the plug-ing on each caller inputs, more control that way.
Each callers voice is different.
Pladin
#4 Posted : Saturday, August 22, 2020 4:06:32 PM(UTC)
Pladin
i use different plugin for different caller inputs.
