Should I apply VST3 Plugins on Audio Bus or vMixCaller inputs?
Joined: 3/23/2020(UTC) Posts: 139  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
If implementing VST3 plug-ins on vMixCallers what is the best practice? Should I apply the plugin to the bus those callers are using or to the individual vMixCall audio inputs? I am specifically referencing plugins like Vocal Rider that dynamically adjusts audio output and noise reduction plugins like NS1 and Izotope RX7? I am thinking NR should be applied to each individual input as noise can vary on each caller but is something like Vocal Rider best applied to a bus or even to Master?
Thanks,
greg
I'm also interested in this. I'm looking to purchase some VST plugins from Waves Audio like the Vocal Rider and Compressor or Noise Reducer. I'm not sure which plugins I should get other than the Vocal Rider, and how best to implement them in vMix. If anyone has some feedback on this it would be much appreciated.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I would use the plug-ing on each caller inputs, more control that way. Each callers voice is different.
Joined: 8/22/2020(UTC) Posts: 1  Location: california
i use different plugin for different caller inputs.
