Should I apply VST3 Plugins on Audio Bus or vMixCaller inputs?
Joined: 3/23/2020(UTC) Posts: 139  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
If implementing VST3 plug-ins on vMixCallers what is the best practice? Should I apply the plugin to the bus those callers are using or to the individual vMixCall audio inputs? I am specifically referencing plugins like Vocal Rider that dynamically adjusts audio output and noise reduction plugins like NS1 and Izotope RX7? I am thinking NR should be applied to each individual input as noise can vary on each caller but is something like Vocal Rider best applied to a bus or even to Master?
Thanks,
greg
Joined: 1/29/2019(UTC) Views messages in topic : 16  Thanks: 2 times
I'm also interested in this. I'm looking to purchase some VST plugins from Waves Audio like the Vocal Rider and Compressor or Noise Reducer. I'm not sure which plugins I should get other than the Vocal Rider, and how best to implement them in vMix. If anyone has some feedback on this it would be much appreciated.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I would use the plug-ing on each caller inputs, more control that way. Each callers voice is different.
Joined: 8/22/2020(UTC) Posts: 1  Location: california
i use different plugin for different caller inputs.
