Feature Requests
More Wipe Transition Options
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: gpdipalmerahtimur  Hi, I think it is good if we have an option to set the Softness of Wipe Border. Currently the Wipe Border is a hard edge and not configurable. Moreover, we need an option to Auto Reverse the Wipe Direction, so if the option is activated, the next Wipe direction should be Right then the afterward will be Left. Otherwise the Wipe Direction will be only Right. Also it will be perfect if we have some different Wipe Patterns like a door closing from Left and Right, window closing from up and down ( YouTube), etc. Thanks in advance. If these are really important to you you can easly simulate them in vMix ( merge ) btw there is already a reversewipe , just choose the other transition
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Originally Posted by: doggy  Originally Posted by: gpdipalmerahtimur  Hi, I think it is good if we have an option to set the Softness of Wipe Border. Currently the Wipe Border is a hard edge and not configurable. Moreover, we need an option to Auto Reverse the Wipe Direction, so if the option is activated, the next Wipe direction should be Right then the afterward will be Left. Otherwise the Wipe Direction will be only Right. Also it will be perfect if we have some different Wipe Patterns like a door closing from Left and Right, window closing from up and down ( YouTube), etc. Thanks in advance. If these are really important to you you can easly simulate them in vMix ( merge ) btw there is already a reversewipe , just choose the other transition Hi Doggy, Thanks for your explanation, can you please tell me how to achieve the transition in the youtube link without having to use Stinger? Currently I used stinger for that. Also, regarding the reverse, do you mean to use two buttons (Wipe and Wipe Reverse)? I mean if we can only hit Wipe button and in the odd count it will go normal and even count it will go reverse. If we choose WipeReverse then the odd count will go from right to left and the event count will go from left to right.
Originally Posted by: gpdipalmerahtimur  Thanks for your explanation, can you please tell me how to achieve the transition in the youtube link without having to use Stinger? Currently I used stinger for that.. this is not done using a stinger but by merging 2 views ! Quote:Also, regarding the reverse, do you mean to use two buttons (Wipe and Wipe Reverse)? I mean if we can only hit Wipe button and in the odd count it will go normal and even count it will go reverse. If we choose WipeReverse then the odd count will go from right to left and the event count will go from left to right. No idea what you are talking about (haven't had my morning coffee yet) to me nothing more disturbing to watch than crazy fancy transitions
Originally Posted by: doggy  Originally Posted by: gpdipalmerahtimur  Thanks for your explanation, can you please tell me how to achieve the transition in the youtube link without having to use Stinger? Currently I used stinger for that.. this is not done using a stinger but by merging 2 views ! Quote:Also, regarding the reverse, do you mean to use two buttons (Wipe and Wipe Reverse)? I mean if we can only hit Wipe button and in the odd count it will go normal and even count it will go reverse. If we choose WipeReverse then the odd count will go from right to left and the event count will go from left to right. No idea what you are talking about (haven't had my morning coffee yet) to me nothing more disturbing to watch than crazy fancy transitions I might do that incorrectly, I tested a black screen merge to a background, but it won't work like in the YouTube instead it is like Fade Transition. Please be kindly advise.
The black bar one ... it's the easiest there is
create a virtual input of the one you want to transition to crop top and bottom to the middle (so basically you wont see anything anymore) Have that one on input and the original one in preview and merge (adjust the timing)
Feature Requests
