#1 Posted : Tuesday, August 11, 2020 4:55:56 PM(UTC)
Originally Posted by: gpdipalmerahtimur Go to Quoted Post
I think it is good if we have an option to set the Softness of Wipe Border. Currently the Wipe Border is a hard edge and not configurable.
Moreover, we need an option to Auto Reverse the Wipe Direction, so if the option is activated, the next Wipe direction should be Right then the afterward will be Left. Otherwise the Wipe Direction will be only Right.
Also it will be perfect if we have some different Wipe Patterns like a door closing from Left and Right, window closing from up and down (YouTube), etc.
Thanks in advance.
If these are really important to you you can easly simulate them in vMix ( merge )
btw there is already a reversewipe , just choose the other transition
gpdipalmerahtimur
#2 Posted : Friday, August 14, 2020 2:11:21 PM(UTC)
gpdipalmerahtimur
Indonesia
Thanks in advance.
Hi Doggy,
Thanks for your explanation, can you please tell me how to achieve the transition in the youtube link without having to use Stinger? Currently I used stinger for that.
Also, regarding the reverse, do you mean to use two buttons (Wipe and Wipe Reverse)? I mean if we can only hit Wipe button and in the odd count it will go normal and even count it will go reverse. If we choose WipeReverse then the odd count will go from right to left and the event count will go from left to right.
#3 Posted : Friday, August 14, 2020 3:58:18 PM(UTC)
Thanks for your explanation, can you please tell me how to achieve the transition in the youtube link without having to use Stinger? Currently I used stinger for that..
this is not done using a stinger but by merging 2 views !
No idea what you are talking about (haven't had my morning coffee yet)
to me nothing more disturbing to watch than crazy fancy transitions
gpdipalmerahtimur
#4 Posted : Friday, August 14, 2020 8:27:39 PM(UTC)
gpdipalmerahtimur
Indonesia
I might do that incorrectly, I tested a black screen merge to a background, but it won't work like in the YouTube instead it is like Fade Transition. Please be kindly advise.
#5 Posted : Friday, August 14, 2020 9:31:49 PM(UTC)
The black bar one ... it's the easiest there is
create a virtual input of the one you want to transition to
crop top and bottom to the middle (so basically you wont see anything anymore)
Have that one on input and the original one in preview and merge (adjust the timing)
gpdipalmerahtimur on 8/15/2020(UTC)
