fabfab10
#1 Posted: : Monday, July 27, 2020 5:07:47 PM(UTC)
fabfab10
Italy
Hello, i'm pretty familiar on how to set up overlay1-4 + stinger on Output menu.
I was wondering if it's possible to setup an overlay channel (let's say Overaly 4) to be used on External Output 2 which is a Blackmagic Decklink SDI output. I've tried without success, so i'm trying to figure out if it's not possible or i'm missing something.
Thanks in advance for your help
BETech
#2 Posted : Monday, July 27, 2020 5:39:57 PM(UTC)
BETech
You can set-up which Overlays & Stringers will appear on any of the four outputs, including Record, Stream, External (1) and External 2.
fabfab10
#3 Posted : Monday, July 27, 2020 6:01:38 PM(UTC)
fabfab10
Italy
Tnx BETech, no matter what i choose i don't get anything on External Output 2.
I have tried to leave all Overlay ON for Output 1 & 2 and i see the graphic only on External Output 1, if i "isolate" Overlay 4 , for example , only on Output 2 i don't get it anywhere.
Does External Output have a different behaviour than "regular output" ie Streaming or recording?
fabfab10
#4 Posted : Monday, July 27, 2020 6:21:03 PM(UTC)
fabfab10
Italy
I think i figured out what the problem is:
2nd External Output is set not to "Output" but to a specific input source. This way none of the overlay channels work.
BETech
#5 Posted : Monday, July 27, 2020 6:44:53 PM(UTC)
BETech
I was about to post, though this information may be useful for others. Make sure your vMix Session Resolution/Frame Rate matches the vMix External Output Resolution/Frame Rate and the Blackmagic Decklink Duo Resolution/Frame Rate.
#6 Posted : Monday, July 27, 2020 6:49:18 PM(UTC)
If you want your overlays to show in external2 when using a specific input, you can trigger them as multiview layers from the overlay input to the specific input
jtarkington
#7 Posted : Wednesday, August 12, 2020 10:10:38 AM(UTC)
jtarkington
@DWAM, can you provide some additional details on how to set that up, may a screen shot or two?
Thanks!
fabfab10
#8 Posted : Wednesday, August 12, 2020 5:16:39 PM(UTC)
fabfab10
Italy
You simply define as multiviewer the source you send to External output 2, then put your source as first layer and logo/graphics on second or third layer.
