Overlay on second external output
Joined: 2/20/2019(UTC) Posts: 68  Location: Firenze Was thanked: 5 time(s) in 5 post(s)
Hello, i'm pretty familiar on how to set up overlay1-4 + stinger on Output menu. I was wondering if it's possible to setup an overlay channel (let's say Overaly 4) to be used on External Output 2 which is a Blackmagic Decklink SDI output. I've tried without success, so i'm trying to figure out if it's not possible or i'm missing something.
Thanks in advance for your help
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 110 time(s) in 71 post(s)
You can set-up which Overlays & Stringers will appear on any of the four outputs, including Record, Stream, External (1) and External 2.
Tnx BETech, no matter what i choose i don't get anything on External Output 2. I have tried to leave all Overlay ON for Output 1 & 2 and i see the graphic only on External Output 1, if i "isolate" Overlay 4 , for example , only on Output 2 i don't get it anywhere. Does External Output have a different behaviour than "regular output" ie Streaming or recording?
I think i figured out what the problem is: 2nd External Output is set not to "Output" but to a specific input source. This way none of the overlay channels work.
I was about to post, though this information may be useful for others. Make sure your vMix Session Resolution/Frame Rate matches the vMix External Output Resolution/Frame Rate and the Blackmagic Decklink Duo Resolution/Frame Rate.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:2nd External Output is set not to "Output" but to a specific input source. If you want your overlays to show in external2 when using a specific input, you can trigger them as multiview layers from the overlay input to the specific input
Joined: 4/16/2020(UTC) Posts: 2  Location: Clayton, NC
@DWAM, can you provide some additional details on how to set that up, may a screen shot or two?
Thanks!
You simply define as multiviewer the source you send to External output 2, then put your source as first layer and logo/graphics on second or third layer.
