john30120
#1 Posted : Wednesday, August 5, 2020 9:35:29 AM(UTC)
john30120
I need to send a simple mute and unmute command to a sound board on our LAN. Apparently a tcp/ip MIDI stream which includes the address, port, MIDI channel, and a few bytes of data will do the trick. Is there a way to do this from within vMix? VB.Net script or shortcut controlled command, perhaps?
Many thanks..
mavik
#2 Posted : Wednesday, August 5, 2020 4:16:04 PM(UTC)
mavik
You might need some sort of bridge between midi and IP. In the early days I did something like this but the other way around. And not with vMix as target. But maybe you get the idea or useful hints by watching it.
I don't know if rtpMIDI and MIDI-OX still exist these days.
Hope that helps a little bit.
