Joined: 8/8/2019(UTC) Posts: 26  Location: Georgia Was thanked: 2 time(s) in 2 post(s)
I need to send a simple mute and unmute command to a sound board on our LAN. Apparently a tcp/ip MIDI stream which includes the address, port, MIDI channel, and a few bytes of data will do the trick. Is there a way to do this from within vMix? VB.Net script or shortcut controlled command, perhaps? Many thanks..
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
You might need some sort of bridge between midi and IP. In the early days I did something like this but the other way around. And not with vMix as target. But maybe you get the idea or useful hints by watching it. I don't know if rtpMIDI and MIDI-OX still exist these days. Hope that helps a little bit.
