jermanprod
#1 Posted : Monday, August 3, 2020 2:06:30 PM(UTC)
jermanprod
I'm trying to use MultiCorder to produce an audio podcast with several vMixCallers engaged in conversation. Because conversational crosstalk between people can cause the audio in vMix to get garbled, I thought MultiCorder would be a great solution to isolate each person's voice and then piece the conversation together cleanly in post. However, MultiCorder seems to be very inconsistent. One caller will have a complete uninterrupted recording, while others will be chopped up in many separate files. For the ones that are chopped up, the MultiCorder doesn't capture everything a person says and will drop whole segments of a person's talk track. I assume what may be happening is that if MultiCorder detects a caller's signal to go weak and fluctuate, it trips the recording. Why won't it be steady like a regular program out recording? In a regular recording of the program out, the recorder doesn't get tripped up if the caller's signal fluctuates. The recording stays rock solid. It doesn't break up the recording into multiple files.
Any insight on this is greatly appreciated.
#2 Posted : Monday, August 3, 2020 4:29:05 PM(UTC)
MultiCorder is a raw recorder by design, this means it records things exactly as they are received.
So if there is timing issues, or breaks in the recording it will not work correctly.
For this reason we do not support vMix Call with MultiCorder. As a workaround you can try routing through
the Outputs1-4 and record those instead.
https://www.vmix.com/kno...lticorder-with-vmix-call
eduardocfs on 8/6/2020(UTC), jermanprod on 8/10/2020(UTC)
#3 Posted : Monday, August 3, 2020 4:38:32 PM(UTC)
Here's a potential solution I have not used for vMixCalls recording (but in others circumstances) that might work
Add a 1920x1080 transparent alpha image on top of your Calls input as a layer. Because this will never fail, I assume it might help to force the recording to carry on whatever happens with the call itself.
Not tested myself but worth a try
#4 Posted : Monday, August 3, 2020 5:14:41 PM(UTC)
That won't work unfortunately as MultiCorder records the raw frames from the source without any input settings applied at all.
That said, recording the outputs instead which have a call input assigned to them will work fine, as the outputs are essentially
full mixes using the full GPU processing on the image (adding duplicate frames etc as needed, scaling to a single resolution at all times etc).
#5 Posted : Monday, August 3, 2020 5:19:19 PM(UTC)
Yes Martin I knew about this, just forgot about it !
scalerious
#6 Posted : Monday, August 10, 2020 11:21:26 PM(UTC)
scalerious
Multicorder seems to break the file when the incoming resolution changes. If a caller's bandwidth changes (as it does, Vmix will do this dynamically) the multicorder starts a new file.
This is frustrating, but how I have gotten around it is to send the caller to an output and record it externally.
I have my 2 Vmix external outputs routed to an SDI pci card which then goes into my atem switcher. But you could hook it directly to a recording monitor like atomos.
hope this helps
thanks 1 user thanked scalerious for this useful post.
jermanprod
#7 Posted : Monday, August 10, 2020 11:27:47 PM(UTC)
jermanprod
Greatly appreciate the responses, everyone. I was hoping to get around the need for extra gear, so I'll try DWAM's suggestion of using a transparent alpha image on top of my Calls (although, not sure how to accomplish this - doesn't seem feasible). If that doesn't work, I'll use the Outputs and record externally.
Guest (4)
Similar Topics
SKype NDI Multicorder Issues (NDI)
by wowgreatoctopus 5/12/2020 11:33:30 PM(UTC)
Multicorder issues (General Discussion)
by FrankLeggett 10/2/2019 11:19:43 PM(UTC)
Multicorder Issues - lots of frame drops (General Discussion)
by thinkcustom 9/15/2016 6:26:01 PM(UTC)
