-TA_
#1 Posted : Friday, July 17, 2020 6:04:20 PM(UTC)
-TA_
Hi!
Wuold this (Dante AVIO Analog Input Adapter 2x0) be a good solution for talent and commentator setup ?
They have open headsets so no need to return audio (they can hear each other). So one ethernet cable with poe and inputs to vMix. And Dante Virtual SoundCard of course.
T.Tommi
andser
#2 Posted : Saturday, July 18, 2020 6:54:09 PM(UTC)
andser
The AVIOS Analog input will not provide phantom power for your mic if needed. Is intended for mixer to network infrastructure purpose. In the Dante routing software is presented as a set of 2ch sources and can be routed anywhere you require. As the source, they work just fine, unattended once setup correctly.
Andy
mavik
#3 Posted : Monday, July 20, 2020 10:13:51 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
You would need a pre-amp if you want to connect a mic directly. The pre-amp will also add the possibility for phantom power. If you plug a dynamic mic directly the level will be too low.
stigaard
#4 Posted : Monday, July 20, 2020 11:01:32 PM(UTC)
stigaard
Denmark
Not necessarily. You can change the signal level configuration for each Dante AVIO to use the expected one, through the Dante Controller app. We had some of these devices on a old firmware which however did not support it, but when installing the latest firmware, you could change what signal level expected.
See i.e. the description on this page: https://www.thomann.de/d...og_input_adapter_2x0.htm :
Adjustable signal levels: +24 dBu / +4 dBu / 0 dBu / 0 dBV / -10 dBV (via Dante controller)
stevespaw
#5 Posted : Tuesday, July 21, 2020 2:21:43 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Mic Level is -60.
Just for the record. Phantom may also be an issue.
Steve
zenvideo
#6 Posted : Tuesday, July 21, 2020 3:35:43 AM(UTC)
zenvideo
Those levels, from -10dBV up to +24dBu, are to cover the various consumer/EBU/SMPTE Line level standards. Definitely not Mic levels, which are more likely to be in the -50dBu down to -70dBu range.
stigaard
#7 Posted : Tuesday, July 21, 2020 3:37:12 AM(UTC)
stigaard
Denmark
Good we have our favorite audio engineer around to clear things up. Thanks Martin.
-TA_
#8 Posted : Monday, July 27, 2020 6:52:34 PM(UTC)
-TA_
Any advise to pre-amp device ?
#9 Posted : Monday, July 27, 2020 7:05:50 PM(UTC)
If you don't want to use a small and cheap mixer or an audio interface that runs without being connected to a computer, you can use these :
https://www.amazon.fr/dp...WZCOS/ref=dp_cerb_1?th=1
But for commentators you will still miss IFB, mute and cough buttons, the ability to set their gain and so on.... Clearly not the ideal setup.
#10 Posted : Monday, July 27, 2020 7:10:39 PM(UTC)
If you want to stick to your idea, just use something like this:
https://www.lyxpro.com/p...-female-to-rj45-ethercon
-TA_
#11 Posted : Monday, July 27, 2020 8:04:37 PM(UTC)
-TA_
Could this one be one choice ? https://www.thomann.de/gb/art_usb_dual_pre.htm .Also 9V battery support
#12 Posted : Monday, July 27, 2020 9:02:05 PM(UTC)
Sort of... but:
- no XLR out (will need adaptors from balanced jacks to xlr)
- it can work alone but for direct connection to loudspeakers
- it's designed to use a computer anyway over USB
- 9V battery is very likely not to last long for phantom power with 2 mics
If I were to do something like this, I would go this way
https://www.thomann.de/g...ger_xenyx_qx1002_usb.htm
with something like this for the transport over CAT5
https://www.lyxpro.com/p...-female-to-rj45-ethercon (there are many solutions like this, for 1, 2, 4 or more channels)
-TA_
#13 Posted : Monday, July 27, 2020 10:44:09 PM(UTC)
-TA_
Sort of... but:
Now I must admit that these audio things are not my area :-). Could you DWAM draw a picture how to connect these and how would Dante suite for this ? RJ45 is going where and how to output audio signal from it ? Or am I totally lost
T.Tommi
#14 Posted : Monday, July 27, 2020 11:05:49 PM(UTC)
Tommy
if you want more help, you'd better tell us more about your needs... Because when I read "commentators and talents" I really wonder what you're trying to do. I would certainly not setup the same solution for commentators as for talents.
Commentators need independent control over their own mix (mute, cough buttons) and they also need IFB with the production crew. Usually they also need video return for the PGM or the replays (so that that can comment on what's live) and they need to know when they are on-air or not
Talents just need good mics and an in-ear monitoring solution.
These are very different use cases.
It also depends on what audio equipments you already have.
I also wonder why you want to go for Dante. Maybe you think this is easier or will let you prevent for buying audio gear but as shown here in this thread it's not really the case.
So explain your idea, your needs and the global context (also your budget) then we can suggest different workflows and alternatives.
stigaard on 7/27/2020(UTC)
mavik
#15 Posted : Tuesday, July 28, 2020 12:17:41 AM(UTC)
mavik
As DWAM said please detail. If you need to use Dante (long run) you can use something like this https://www.thomann.de/de/neutrik_na2_io_dline.htm for I/O somewhere in the network but keep in mind that you need to feed proper signals into it. On the computer you additionally would need Via or DVS deal with the interface.
-TA_
#16 Posted : Tuesday, July 28, 2020 3:10:01 AM(UTC)
-TA_
Would this work ? Or do I need still pre-amp between headsets and Neutrix
https://drive.google.com...Hf3VUno/view?usp=sharing
Tommi
Guest (4)
Similar Topics
Dante AVIO USB (General Discussion)
by waldron18 4/23/2025 9:41:24 PM(UTC)
Dante AVIO analog input (Hardware Compatibility)
by u2h2i2 11/2/2020 11:19:03 PM(UTC)
