                hi all i try to do something and doesnt work may be it CANT?? i explain i make a LIST (m3) and i want a trigger between some  in the trigger oncompletion / stinger (for example) / mylist/ and under you can find the video from the LIST  but doesnt work?? Normal? Thanks David
 Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
                triggers only work on inputs
  if the input is a container for inputs, triggers can't be applied within the container but only to the container itself
  so you can create your list to include your stinger between each input like this for example - input1 - stinger - input2 - stinger - input3 -...
  This will run automatically
  OR
  you can do it manually
                Ok thanks i will check David
                Hi I check but my stinger have a chromakey so they dont take the key in the list? Thanks David
 Joined: 12/27/2012(UTC) Posts: 5,453  Location: Belgium Thanks: 311 times Was thanked: 1008 time(s) in 830 post(s)
                Originally Posted by: davidcl  Hi I check but my stinger have a chromakey so they dont take the key in the list? Thanks David  JMO As a stinger is basically used to "progressively hide/cover" the transition of 2 subsequent clips by means of  another clip or animation playing that stinger between the 2 clips would not need some  transparency at all as there is no overlap anyway nor is it overlayed  One way i see the possibility of using a stinger automatically and correctly in a list between clip is by scripting, based on the timeline of the clip being played combined with the duration of the stinger clip/animation to  instruct overlaying  the stinger during the switch/transition between clips in the list.
                hi Doggy Thanks but never used Script i dont know how working? Do you have and sample please Imagine a list (for example : "advertissings list" with stinger (with key) for progressing hide/cover like you say) PUB 1 Stinger 1 PUB 2 stinger 1 PUB 3 stinger 1 ...
  Thanks for your help David
                Originally Posted by: davidcl  hi Doggy Thanks but never used Script i dont know how working? Do you have and sample please Imagine a list (for example : "advertissings list" with stinger (with key) for progressing hide/cover like you say) PUB 1 Stinger 1 PUB 2 stinger 1 PUB 3 stinger 1 ...
  Thanks for your help David  Don't know why you would actually use a stinger between commercials but each his own i guess ;-) But i can sort of understand as using a list  the transition between the clips is a cut  Using a playlist one can specify the transitions between clips including stingers (have to specify it with each item in that list) note : stinger us the standard way if you want to go the list route one is not going to use the stinger function but rather the input itself used as stinger to be overlayed at the right time between the various clips. This input needs to be set to be triggered to overlay out oncompletion while the script will activate the overlay its trickier to time etc  There is an example script here  https://forums.vmix.com/...ng-for-Dummies#post71985with a few modification ; like instructing to overlay your stinger input , adding a little pause after that etc it works  That is without taking into account activating and/or deactivating the script for other mixing you want to do etc  As usual different ways to do things, pick your favorite or suited to your production
