davidcl
#1 Posted : Thursday, July 16, 2020 1:28:57 AM(UTC)
davidcl
Gabon
hi all
i try to do something and doesnt work may be it CANT??
i explain
i make a LIST (m3)
and i want a trigger between some
in the trigger oncompletion / stinger (for example) / mylist/ and under you can find the video from the LIST
but doesnt work??
Normal?
David
#2 Posted : Thursday, July 16, 2020 5:48:17 PM(UTC)
triggers only work on inputs
if the input is a container for inputs, triggers can't be applied within the container but only to the container itself
so you can create your list to include your stinger between each input like this for example
- input1
- stinger
- input2
- stinger
- input3
This will run automatically
OR
you can do it manually
davidcl
#3 Posted : Thursday, July 16, 2020 6:20:13 PM(UTC)
davidcl
Gabon
Ok thanks i will check
David
davidcl
#4 Posted : Friday, July 17, 2020 7:42:50 PM(UTC)
davidcl
Gabon
Hi
I check but my stinger have a chromakey so they dont take the key in the list?
David
#5 Posted : Friday, July 17, 2020 8:17:19 PM(UTC)
Originally Posted by: davidcl Go to Quoted Post
Hi
David
JMO
As a stinger is basically used to "progressively hide/cover" the transition of 2 subsequent clips by means of another clip or animation playing that stinger between the 2 clips would not need some transparency at all as there is no overlap anyway nor is it overlayed
One way i see the possibility of using a stinger automatically and correctly in a list between clip is by scripting, based on the timeline of the clip being played combined with the duration of the stinger clip/animation to
instruct overlaying the stinger during the switch/transition between clips in the list.
davidcl
#6 Posted : Friday, July 17, 2020 8:28:11 PM(UTC)
davidcl
Gabon
hi Doggy
Thanks but never used Script i dont know how working?
Do you have and sample please
Imagine a list (for example : "advertissings list" with stinger (with key) for progressing hide/cover like you say)
PUB 1
Stinger 1
PUB 2
stinger 1
PUB 3
stinger 1
Thanks for your help
David
#7 Posted : Friday, July 17, 2020 9:37:38 PM(UTC)
hi Doggy
PUB 1
Stinger 1
PUB 2
stinger 1
PUB 3
stinger 1
David
Don't know why you would actually use a stinger between commercials but each his own i guess ;-)
But i can sort of understand as using a list the transition between the clips is a cut
Using a playlist one can specify the transitions between clips including stingers (have to specify it with each item in that list) note : stinger us the standard way
if you want to go the list route one is not going to use the stinger function but rather the input itself used as stinger to be overlayed at the right time between the various clips.
This input needs to be set to be triggered to overlay out oncompletion while the script will activate the overlay
its trickier to time etc
There is an example script here https://forums.vmix.com/...ng-for-Dummies#post71985
with a few modification ; like instructing to overlay your stinger input , adding a little pause after that etc it works
That is without taking into account activating and/or deactivating the script for other mixing you want to do etc
As usual different ways to do things, pick your favorite or suited to your production
Similar Topics
List Triggers (General Discussion)
by buntonn 6/17/2026 8:59:30 PM(UTC)
