alexbyrd
#1 Posted : Saturday, January 11, 2020 7:56:50 AM(UTC)
alexbyrd
Was thanked: 6 time(s) in 3 post(s)
Hi
Has anyone managed to get vmix to send an SRT stream out to the internet to a wowza server and then send it back again? We are looking at a way to do some external processing to a live stream but bring it back in again on low bandwidth connections and having the reliability would be good.
I have managed to get vmix to vmix / vlc to work over SRT but am missing something with getting the wowza server to see it.
any feedback welcome.
Best
Alex.
sam602
#2 Posted : Wednesday, January 15, 2020 10:38:33 PM(UTC)
sam602
Trinidad And Tobago
Create you caller srt output in vMix. DO not use the passphase feature.
On the WOWZA Server create a stream file srt://0.0.0.0:####(port used in vMix) ...assign latercy in properties ...Angain donot use passphase.
Connect to SRT mediacache
THE RETURN..
USE TARGET... Also donot use passphase.
Note..WOWZA currently working on changes to make it more compatible to vMix.
cassaranks
#3 Posted : Saturday, June 27, 2020 4:52:58 AM(UTC)
cassaranks
Has anyone gotten VMIX to connect to Wowza using SRT?
apocnz
#4 Posted : Friday, July 10, 2020 4:57:18 AM(UTC)
apocnz
I'm using it with no issues (to Wowza Cloud).
xaver
#5 Posted : Friday, July 10, 2020 5:07:00 AM(UTC)
xaver
Originally Posted by: sam602 Go to Quoted Post
THE RETURN..
But how can I send a SRT from WOWZA to vMix, if vMix is behind a router, where I can't change the rules
with RTSP I can get the stream from WOWZA, is there also a way to "get" the SRT from WOWZA
ask
#6 Posted : Friday, July 10, 2020 8:04:04 AM(UTC)
ask
If you can't add a port-forward rule, you can't receive an SRT channel.
xaver
#7 Posted : Thursday, July 16, 2020 8:19:57 PM(UTC)
xaver
get the access to the router
which ports must I forward?
#8 Posted : Thursday, July 16, 2020 9:29:47 PM(UTC)
The ones you decide
stevespaw
#9 Posted : Thursday, July 16, 2020 10:48:52 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Sure you can! if you can make the Wowza a listener - or rendezvous. That is what makes SRT awesome
Steve
