SRT
str to wowza server and back
Was thanked: 9 time(s) in 4 post(s)
Hi
Has anyone managed to get vmix to send an SRT stream out to the internet to a wowza server and then send it back again? We are looking at a way to do some external processing to a live stream but bring it back in again on low bandwidth connections and having the reliability would be good.
I have managed to get vmix to vmix / vlc to work over SRT but am missing something with getting the wowza server to see it.
any feedback welcome.
Best
Alex.
Joined: 5/8/2019(UTC) Posts: 37  Location: Port of Spain Thanks: 14 times Was thanked: 1 time(s) in 1 post(s)
Create you caller srt output in vMix. DO not use the passphase feature. On the WOWZA Server create a stream file srt://0.0.0.0:####(port used in vMix) ...assign latercy in properties ...Angain donot use passphase. Connect to SRT mediacache
THE RETURN..
USE TARGET... Also donot use passphase. Note..WOWZA currently working on changes to make it more compatible to vMix.
Has anyone gotten VMIX to connect to Wowza using SRT?
I'm using it with no issues (to Wowza Cloud).
Originally Posted by: sam602
THE RETURN..
But how can I send a SRT from WOWZA to vMix, if vMix is behind a router, where I can't change the rules with RTSP I can get the stream from WOWZA, is there also a way to "get" the SRT from WOWZA
If you can't add a port-forward rule, you can't receive an SRT channel.
If you can't add a port-forward rule, you can't receive an SRT channel. get the access to the router which ports must I forward?
Quote:which ports must I forward? The ones you decide
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
If you can't add a port-forward rule, you can't receive an SRT channel. Sure you can! if you can make the Wowza a listener - or rendezvous. That is what makes SRT awesome Steve
SRT
