wwdv
#1 Posted : Saturday, January 18, 2014 3:53:29 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
Is it possible to stream from mpeg4/mjpeg PTZ IP camera's like the Sony SNC-RZ30?
If so where can I enter the username/password?
I don't see this fields in the stream input in vMix.
Killerhands
#2 Posted : Sunday, January 19, 2014 1:49:53 AM(UTC)
Killerhands
Use the following syntax:
Code:
rtsp://username:password@192.168.X.XXX/live/h264
Replace the variables and you should be good to go :)
wwdv
#3 Posted : Sunday, January 19, 2014 7:37:07 AM(UTC)
wwdv
I connected a Axis 207 camera with rtsp support, but I got this error: No Session
Conclusion: vMix only supports H264 and Axis apparently does not.
That's too bad, a lot of camera's only do mjpeg and mpeg4.
wscawebcast
#4 Posted : Friday, January 24, 2014 9:06:17 PM(UTC)
wscawebcast
It may depend on the Axis camera model. I'm using Axis P3346 with h.264 and this URL for Stream input in vMix:
rtsp://<ip address>/axis-media/media.amp
The manual for the Axis camera provided a number of different URLs for different formats and transports (UDP, TCP, etc.)
wwdv
#5 Posted : Tuesday, January 28, 2014 1:23:04 PM(UTC)
wwdv
What is your camera delay?
I tested with a Sony SNC-ZP550 and I've got more then 1 second delay.
wscawebcast
#6 Posted : Tuesday, January 28, 2014 2:12:19 PM(UTC)
wscawebcast
Normally "zero" delay. We're showing the same cameras on a separate PC/monitor via VLC, and we're getting the same performance on the vMix PC. The cameras are hardwired (PoE) to the router, as are both PCs.
wwdv
#7 Posted : Wednesday, January 29, 2014 3:27:19 PM(UTC)
wwdv
There is always some buffering delay.
So it can't be realtime.
wwdv
#8 Posted : Wednesday, January 29, 2014 3:38:20 PM(UTC)
wwdv
Code:
I have to set the camera to unauthorized viewer.
rtsp://user:password@192.168.1.xxx/media/video1 doesn't work: 401 unauthorized
