How to add a ip camera with username/password?
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
Is it possible to stream from mpeg4/mjpeg PTZ IP camera's like the Sony SNC-RZ30? If so where can I enter the username/password? I don't see this fields in the stream input in vMix.
Use the following syntax: Code:rtsp://username:password@192.168.X.XXX/live/h264
Replace the variables and you should be good to go :)
I connected a Axis 207 camera with rtsp support, but I got this error: No Session
Conclusion: vMix only supports H264 and Axis apparently does not.
That's too bad, a lot of camera's only do mjpeg and mpeg4.
Joined: 1/6/2014(UTC) Posts: 38 Location: Seattle, WA
It may depend on the Axis camera model. I'm using Axis P3346 with h.264 and this URL for Stream input in vMix:
rtsp://<ip address>/axis-media/media.amp
The manual for the Axis camera provided a number of different URLs for different formats and transports (UDP, TCP, etc.)
What is your camera delay? I tested with a Sony SNC-ZP550 and I've got more then 1 second delay.
Normally "zero" delay. We're showing the same cameras on a separate PC/monitor via VLC, and we're getting the same performance on the vMix PC. The cameras are hardwired (PoE) to the router, as are both PCs.
wscawebcast wrote:Normally "zero" delay. There is always some buffering delay. So it can't be realtime.
Killerhands wrote:Use the following syntax: Code:rtsp://username:password@192.168.X.XXX/live/h264
Replace the variables and you should be good to go :) I have to set the camera to unauthorized viewer. rtsp://user:password@192.168.1.xxx/media/video1 doesn't work: 401 unauthorized
