How to use the setfader shortcut
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
It has a delay setting but no value setting. If I start the effect nothing happens.
It should be very nice if this shortcut is working with a delay for a smooth transition. (the api setfader command has no delay option)
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Use the Fade function instead if you want a timed transition.
Martin vMix
The fade effect can not stop halfway, I need to mix 50%, with setfader=128 I can do that.
Could use an overlay channel setting the alpha to 128.
My overlay channels are all in use, there are only 4 of them. Why is there a setfader option in shortcuts when it doesn't work? :)
SetFader is used to set a specific mix value between 0 and 255 It is not designed to be used to animate the mix.
Martin vMix
I think you misundertood me, I do not mean the api setfader command. That is working OK (Function=SetFader&Value=128).
I want to use the Setfader shortcut command and that doesn't work. It has only a duration parameter and no value parameter. If I enter 128 in the duration parameter it isn't working either.
Sorry for the misunderstanding. SetFader was created for the API, but I will see about enabling it as a shortcut as well.
The "function" dropdown box for the shortcuts and api is the same so there is going to be a few items in the list that do not apply to shortcuts, I apologise for the confusion.
