wwdv
#1 Posted : Thursday, January 23, 2014 7:54:35 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
It has a delay setting but no value setting.
If I start the effect nothing happens.
It should be very nice if this shortcut is working with a delay for a smooth transition.
(the api setfader command has no delay option)
#2 Posted : Thursday, January 23, 2014 10:19:52 PM(UTC)
Use the Fade function instead if you want a timed transition.
wwdv
#3 Posted : Friday, January 24, 2014 2:44:55 PM(UTC)
wwdv
The fade effect can not stop halfway, I need to mix 50%, with setfader=128 I can do that.
#4 Posted : Saturday, January 25, 2014 1:03:08 AM(UTC)
Could use an overlay channel setting the alpha to 128.
wwdv
#5 Posted : Saturday, January 25, 2014 2:13:08 PM(UTC)
wwdv
My overlay channels are all in use, there are only 4 of them.
Why is there a setfader option in shortcuts when it doesn't work? :)
#6 Posted : Saturday, January 25, 2014 11:00:39 PM(UTC)
SetFader is used to set a specific mix value between 0 and 255
It is not designed to be used to animate the mix.
wwdv
#7 Posted : Sunday, January 26, 2014 7:51:10 AM(UTC)
wwdv
I think you misundertood me, I do not mean the api setfader command.
That is working OK (Function=SetFader&Value=128).
I want to use the Setfader shortcut command and that doesn't work.
It has only a duration parameter and no value parameter.
If I enter 128 in the duration parameter it isn't working either.
#8 Posted : Monday, January 27, 2014 12:05:11 AM(UTC)
Sorry for the misunderstanding.
SetFader was created for the API, but I will see about enabling it as a shortcut as well.
The "function" dropdown box for the shortcuts and api is the same so there is
going to be a few items in the list that do not apply to shortcuts, I apologise for the confusion.
wwdv on 1/27/2014(UTC)
