micahjb
#1 Posted : Sunday, June 21, 2020 2:14:18 PM(UTC)
micahjb
With the floating point math it's challenging to get pixel accurate designs in the multiviews.
Please implement an option to shift to pixel based adjustments for display size and horizontal and vertical positioning.
thanks 1 user thanked micahjb for this useful post.
vvcvvc on 6/29/2020(UTC)
vvcvvc
#2 Posted : Monday, June 29, 2020 7:21:43 AM(UTC)
vvcvvc
Estonia
+1
David_in_Philly
#3 Posted : Tuesday, June 30, 2020 3:43:32 AM(UTC)
David_in_Philly
Was thanked: 14 time(s) in 9 post(s)
+1
mavik
#4 Posted : Tuesday, June 30, 2020 7:47:09 PM(UTC)
mavik
+1
I would add magnetic objects on/off. If you get close to another border it snaps to that object.
mvoccola
#5 Posted : Sunday, July 5, 2020 12:32:29 AM(UTC)
mvoccola
This is absolutely critical. We often get design guides with pixel-placement (either top-left or center) positions of on-screen elements and cropping. For example, a 2-UP shot on a background that has graphics designed to precisely border the PiP. Another example is a pre-rendered animated L3 that would go over each of the PiPs.
Paul Camino
#6 Posted : Wednesday, July 8, 2020 2:18:26 PM(UTC)
Paul Camino
+1 on integer pixel based coordinate mapping
I would also add, Integer based window cropping as well.
richardgatarski
#7 Posted : Wednesday, July 8, 2020 6:11:00 PM(UTC)
richardgatarski
+1
epicenter800
#8 Posted : Thursday, July 9, 2020 8:21:10 AM(UTC)
epicenter800
+1
beedegee
#9 Posted : Friday, July 10, 2020 6:07:13 PM(UTC)
beedegee
+1
Yes please! Something like the Title Design application.
KennyStokes
#10 Posted : Saturday, July 11, 2020 1:30:45 AM(UTC)
KennyStokes
Was thanked: 8 time(s) in 1 post(s)
+1
tsioukas
#11 Posted : Saturday, July 11, 2020 9:46:34 PM(UTC)
tsioukas
Greece
+1, also use anchor points of that. For example X and Y pixels from bottom right corner, or top center etc. This will make easy to match design positions (Illustration, After Effects etc) with vMIX positioning.
Nikb72
#12 Posted : Tuesday, July 14, 2020 12:25:17 AM(UTC)
Nikb72
+1 for pixel based positioning
+1 for selectable anchor point
Also would be great to be able to save a (multiple) position(s) & apply it to other multiviews
