Hello, everyone! I was wondering as I am new to vmix is it possible to have a second person on the same vmix system with a screen and a keyboard that does IR shortcuts and letting him cut out moments of a sports game and having the main guy switching cameras, overlays etc. So in breaks and small intermission there could be a replay or couple that it could play instantly.
Joined: 12/27/2012(UTC) Posts: 5,459  Location: Belgium Thanks: 312 times Was thanked: 1009 time(s) in 831 post(s)
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
Not only is it possible but its really already built for that if you buy controllers that you can simply download the shortcuts and triggers.
For example you could buy a pre loaded VMIX X-Keys switcher and X-Keys replay controller and go in and load them for presets already created. Aside from X-Keys there are a number of other pre configured switcher and replay controllers. A Shuttle pro is a really cheap pre assigned controller for replay.
You then would only need to get your screen workflow situated. For instance you might chose to have a dedicated screen as a Multiview and a Fullscreen setup for your replay op combined with a program monitor for your talent. All possible assuming your system can handle the workflow.
The cool thing is you can switch between having a dedicated op for larger events and doing it all from one op/one screen on smaller events. You can just setup your sessions to match your needs.
Joined: 2/18/2018(UTC) Posts: 39  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Be aware though - you can't run Multicorder recordings and Instant Replay at the same time on the one machine. If you're ISO recording on the cameras themselves though, that's not a dealbreaker.
