shftctrl
#1 Posted : Sunday, June 28, 2020 6:18:56 AM(UTC)
shftctrl
Latvia
Hello, everyone! I was wondering as I am new to vmix is it possible to have a second person on the same vmix system with a screen and a keyboard that does IR shortcuts and letting him cut out moments of a sports game and having the main guy switching cameras, overlays etc. So in breaks and small intermission there could be a replay or couple that it could play instantly.
#2 Posted : Sunday, June 28, 2020 7:48:14 AM(UTC)
yes
Radiotvpat1982
#3 Posted : Sunday, June 28, 2020 7:54:51 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
Not only is it possible but its really already built for that if you buy controllers that you can simply download the shortcuts and triggers.
For example you could buy a pre loaded VMIX X-Keys switcher and X-Keys replay controller and go in and load them for presets already created. Aside from X-Keys there are a number of other pre configured switcher and replay controllers. A Shuttle pro is a really cheap pre assigned controller for replay.
You then would only need to get your screen workflow situated. For instance you might chose to have a dedicated screen as a Multiview and a Fullscreen setup for your replay op combined with a program monitor for your talent. All possible assuming your system can handle the workflow.
The cool thing is you can switch between having a dedicated op for larger events and doing it all from one op/one screen on smaller events. You can just setup your sessions to match your needs.
TFMG
#4 Posted : Monday, June 29, 2020 10:16:00 AM(UTC)
TFMG
Be aware though - you can't run Multicorder recordings and Instant Replay at the same time on the one machine. If you're ISO recording on the cameras themselves though, that's not a dealbreaker.
