Thanks: 24 times Was thanked: 10 time(s) in 8 post(s)
admin wrote:
* MarkIn, MarkOut shortcuts. * SetRate shortcut which can be set to 1 for 100%, 1.5 for 150% etc, or it can be set to +=0.5 -=0.5 etc to increase/decrease the speed by 50% each time. The +=, -= format will also be possible with SetPosition so you can jump backwards or forwards.
* Separate Play, Pause shortcuts * Separate OverlayIn, OverlayOut shortcuts * SelectPlayList shortcut to select playlist by name.
* List shuffle and drag and drop editing * Ability to Import and Export virtual sets after making changes
Just great !! Thanks Martin
Will Martin be streaming his booth live from NAB 2014?
I am sure all of us vMix users around the globe will love to see him demonstrate some of these features live as well as follow the progress of vMix at the event.
Thanks.
Rottimmy
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
admin wrote:Anyway the following additional features will be available in vMix 12:
Great new features. I'm really looking forward to v12. Thank you for your great work.
admin wrote:Work has begun on vMix 12 which is expected to be released early next year. There are also two major new features in the works which will not be revealed until shortly before NAB 2014!
Features
* Support for MOV and MXF files in vMix x64 * Input Triggers - Select one more actions when an Input finishes playback, such as fade to Preview. * Select which inputs from a preset to load and append them to an existing session. * Change name of capture devices * Playback speeds saved in Presets * Instead of selecting audio sources for Recording, Streaming and External Output, they will now all use a single audio source configured from Settings. This will default to "vMix Audio" but a sound card input can be selected if you want to do your own mixing. * XAML support for two storyboards, one for "In" overlay animations and one for "Out" * Set a video delay on each capture input independently of the "Video Delay" feature
Upgrade Note
Customers who have purchased vMix in the last 12 months will receive vMix 12 for free when it is released. All other customers can purchase an upgrade for a fixed price of $59.
Martin vMix A MUST BE FEATURE: Lets us to set a position in a video where an overlay input should be appear. For example: We select in a video that at 2 minutes an overlay have to appear. Then, when the video timeline set 2 minutes, the overlay appear. Is it possible?? PLEASE, DO IT FOR US!
Joined: 11/8/2013(UTC) Posts: 87  Location: Bavaria, Germany Thanks: 6 times Was thanked: 19 time(s) in 10 post(s)
admin wrote: Anyway the following additional features will be available in vMix 12:
Plus two big secret features that will be announced at NAB 2014!
Martin vMix
Sounds pretty good, Martin. Many "problems" (or inconveniences) in sports production will be solved with vMix 12. Can't wait for beta release... Regards Karsten
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
Damn2Good4U wrote:Will Martin be streaming his booth live from NAB 2014?
Thanks.
Rottimmy i have some streaming capacity available :) M@ik
admin wrote:Transitions within the List feature is a complex thing to implement due to duration problems with certain video formats. (An MP4 might say it is 30 seconds long, but in actuality is 32, meaning vMix would transition too early in most cases)
Just a thought on this.... Would it be easy enough to use the audio track in the video to use as the marker for tack length? Of course that means the video has to have an actual audio track incorporated, but we wouldn't need to use it in the audio output. Just use it x seconds from the end of the audio track. But then again, I'm not familiar with how video tracks are built, so maybe it's simply I don't understand. The Video software I use separates a video into 2 channels, the audio, and the video. I assume this is the case in most video formats.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
