themann00
#1 Posted : Friday, June 19, 2020 10:24:53 PM(UTC)
themann00
I need to delay an NDI capture by 12 frames to sync with audio.
The delay video under advanced is greyed out for that input- and it seems to be greyed out on all inputs.
Is there a way to enable it?
delay video greyed out
xaver
#2 Posted : Friday, June 19, 2020 10:40:34 PM(UTC)
xaver
here (23.0.0.57) I can delay NDI, but not Stream (RTSP) or vMix Calls
#3 Posted : Friday, June 19, 2020 11:38:56 PM(UTC)
Output that input to NDI and back in as NDI and add delay
themann00
#4 Posted : Saturday, June 20, 2020 12:54:39 AM(UTC)
themann00
Do what now??
#5 Posted : Saturday, June 20, 2020 1:54:23 AM(UTC)
Do what now??
NDI input HAS delay option
if its not an NDI feed, output that input as NDI and bring that NDi back in to get the delay option
themann00
#6 Posted : Saturday, June 20, 2020 2:17:17 AM(UTC)
themann00
Do what now??
Is there a quick/easy link to the procedure for that? I've never done it before, and a quick scan though settings and options, I'm not sure where to start. Manual or video (and I'm opening up the manual now, may find it on my own, but just trying to stay on top of this before my next scheduled call today!)
#7 Posted : Saturday, June 20, 2020 2:44:25 AM(UTC)
your first problem is you havent tested enough
second , kind of late to go through the helpfiles and then not be able to test
Kind of strange you mentioned a video in source too which apparently isn't
on the other hand there is this tool called Google search which will lead you to a S...load of vMix instructional videos (from vMix itself noless)
suggest also to brush up on how a call comes in ;-)
