Joined: 5/1/2019(UTC) Posts: 34  Location: Indianapolis Thanks: 4 times
I need to delay an NDI capture by 12 frames to sync with audio. The delay video under advanced is greyed out for that input- and it seems to be greyed out on all inputs. Is there a way to enable it?
here (23.0.0.57) I can delay NDI, but not Stream (RTSP) or vMix Calls
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Output that input to NDI and back in as NDI and add delay
Originally Posted by: doggy  Output that input to NDI and back in as NDI and add delay Do what now??
Originally Posted by: themann00  Originally Posted by: doggy  Output that input to NDI and back in as NDI and add delay Do what now?? NDI input HAS delay option if its not an NDI feed, output that input as NDI and bring that NDi back in to get the delay option
Originally Posted by: doggy  Originally Posted by: themann00  Originally Posted by: doggy  Output that input to NDI and back in as NDI and add delay Do what now?? NDI input HAS delay option if its not an NDI feed, output that input as NDI and bring that NDi back in to get the delay option Is there a quick/easy link to the procedure for that? I've never done it before, and a quick scan though settings and options, I'm not sure where to start. Manual or video (and I'm opening up the manual now, may find it on my own, but just trying to stay on top of this before my next scheduled call today!)
your first problem is you havent tested enough second , kind of late to go through the helpfiles and then not be able to test Kind of strange you mentioned a video in source too which apparently isn't on the other hand there is this tool called Google search which will lead you to a S...load of vMix instructional videos (from vMix itself noless) suggest also to brush up on how a call comes in ;-)
