SRT
Issue with SRT (seems interlaced)
Rank:: Newbie
Joined: 6/5/2020(UTC) Posts: 3   Location: Santa Cruz do Sul
Hello, I have a issue with SRT. During tests with V-Mix software, I enable SRT output in a PC 1. On the PC 2 (as Listener), the image received seems have problem how a interlaced image. The PC 2 also send image for a two video monitors way DeckLink output, and the image in the monitors, are perfect, without problem. https://youtu.be/NFfSw_Hl7BQBetween 1:00 and 1:21 you can see the problem Thanks a lot.
Joined: 5/12/2020(UTC) Posts: 7  Location: Los Angeles
The only way I've been able to deinterlace an SRT source is to create a virtual input of the source and choose Deinterlace Blend from the General tab.
Rank:: Newbie
Hi SheepishMoose,
Thank you for your reply.
I'm going to test this alternative. But the question is still: why did this happen?
What is your Master Frame Rate set as on PC 1?
Rank:: Newbie
I tested with 30p and 60p (camera, capture card, project, all set configured on resolution and fps)
Joined: 1/13/2010(UTC) Posts: 5,354  Location: Gold Coast, Australia Was thanked: 4765 time(s) in 1636 post(s)
SRT in vMix does not support Interlaced, so make sure your Master Frame Rate in Settings -> Display is only set to a "p" frame rate.
SRT
