SRT
Issue with SRT (seems interlaced)
Joined: 6/5/2020(UTC) Posts: 3   Location: Santa Cruz do Sul
Hello, I have a issue with SRT. During tests with V-Mix software, I enable SRT output in a PC 1. On the PC 2 (as Listener), the image received seems have problem how a interlaced image. The PC 2 also send image for a two video monitors way DeckLink output, and the image in the monitors, are perfect, without problem. https://youtu.be/NFfSw_Hl7BQBetween 1:00 and 1:21 you can see the problem Thanks a lot.
Joined: 5/12/2020(UTC) Posts: 7  Location: Los Angeles
The only way I've been able to deinterlace an SRT source is to create a virtual input of the source and choose Deinterlace Blend from the General tab.
Hi SheepishMoose,
Thank you for your reply.
I'm going to test this alternative. But the question is still: why did this happen?
What is your Master Frame Rate set as on PC 1?
I tested with 30p and 60p (camera, capture card, project, all set configured on resolution and fps)
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
SRT in vMix does not support Interlaced, so make sure your Master Frame Rate in Settings -> Display is only set to a "p" frame rate.
SRT
