Anselmo
#1 Posted : Friday, June 5, 2020 4:31:55 AM(UTC)
Anselmo
Brazil
I have a issue with SRT. During tests with V-Mix software, I enable SRT output in a PC 1. On the PC 2 (as Listener), the image received seems have problem how a interlaced image. The PC 2 also send image for a two video monitors way DeckLink output, and the image in the monitors, are perfect, without problem.
https://youtu.be/NFfSw_Hl7BQ
Between 1:00 and 1:21 you can see the problem
Thanks a lot.
SheepishMoose
#2 Posted : Wednesday, June 10, 2020 3:00:40 AM(UTC)
SheepishMoose
The only way I've been able to deinterlace an SRT source is to create a virtual input of the source and choose Deinterlace Blend from the General tab.
Anselmo
#3 Posted : Wednesday, June 10, 2020 5:44:42 AM(UTC)
Anselmo
Brazil
Hi SheepishMoose,
Thank you for your reply.
I'm going to test this alternative. But the question is still: why did this happen?
SheepishMoose
#4 Posted : Wednesday, June 10, 2020 6:25:44 AM(UTC)
SheepishMoose
What is your Master Frame Rate set as on PC 1?
Anselmo
#5 Posted : Wednesday, June 10, 2020 6:49:34 AM(UTC)
Anselmo
Brazil
I tested with 30p and 60p (camera, capture card, project, all set configured on resolution and fps)
#6 Posted : Wednesday, June 10, 2020 12:03:28 PM(UTC)
Was thanked: 4675 time(s) in 1610 post(s)
SRT in vMix does not support Interlaced, so make sure your Master Frame Rate
in Settings -> Display is only set to a "p" frame rate.
