PhillBarrs
#1 Posted : Friday, May 8, 2020 1:39:29 AM(UTC)
PhillBarrs
Hi everyone, I'm currently live streaming using Livestream studio to stream with, but looking to switch to Vmix mainly because to the more remote guest and more compatible with iPhones. But having looked in on the Vmix software I have a dew questions that I don't seem to be able to find the answered for, so hoping for some help.
In live stream studio there are two main features that I find very helpful and hope they are available in Vmix and I just don't know where to look.
1, The secondary click mouse option when switching between, sources. As can't find how to change the settings if it is.
2 On Livestream Studio when remote guest come in, I can see their downloading speeds, can this also be done in Vmix?
Any help would be amazing, and thank you.
Phill
ask
#2 Posted : Friday, May 8, 2020 9:19:34 AM(UTC)
ask
Can you explain what you are wanting to do here?
Yes
PhillBarrs
#3 Posted : Friday, May 8, 2020 9:28:07 AM(UTC)
PhillBarrs
Hi there so on the first part. For example any input source if you right click once it goes to your output or if you left click it goes to your preview box. I know I have my maths set up correctly because it works on live stream studio so I was wondering is there a setting within the vmix I need to change?
And on the second part could you explain how I see the speeds because when I bring remote callers in all I see is their picture but no downloading speeds?
ask
#4 Posted : Friday, May 8, 2020 9:41:38 AM(UTC)
ask
By default when you left-click over the input, that input is sent to Preview. You can use the Cut or Quick-Play buttons to send to Program. You can change the behaviour of the left-click on the Settings/General tab of that input. https://www.vmix.com/hel...nputSettingsGeneral.html
You can also setup shortcuts (keyboard or external controller to send the input to either destination. https://www.vmix.com/hel...dex.htm?AddShortcut.html
Don't expect exactly the same behaviour in both programs. They deliver the same end result slightly differently.
https://www.vmix.com/hel...htm?CallManagerChat.html
PhillBarrs
#5 Posted : Friday, May 8, 2020 8:12:33 PM(UTC)
PhillBarrs
Thank you for this
KnKproductions
#6 Posted : Friday, May 8, 2020 9:02:11 PM(UTC)
KnKproductions
Be aware, setting up a shortcut to use the right-click of a mouse to send an input to the main program window will take away a lot of functionality... vmix uses menus that arise from right-clicking inputs.
Maybe it'd be best to set up the middle-click on the scroll wheel (if available) as the shortcut.
Similar Topics
Advice needed: Stream 1080p to internet, record Mpeg2-ts 50i for TV (General Discussion)
by witsok 5/7/2019 1:38:18 AM(UTC)
