witsok
#1 Posted : Tuesday, May 7, 2019 1:38:18 AM(UTC)
witsok
Here are my laptop specs:
geforce gtx 765m 2 GB
intel 4600
i7-4700mq (2.4 GHz)
SSD 120GB drive
HDD 500GB drive
16GB RAM
win7 64bit
vmix ver: 21.0.0.61 x64
My video camera output (Panasonic AG-HMC 150): 1080p 25 fps
Situation: I want to do a live full-hd stream to Youtube at 1080p25 3.5 Mbps and record the vMix output on a local drive. Both at the same time.
The live stream is fine, but the recording must be in mpeg2-ts 50i format for broadcast by local TV. That's a must.
The recording setup is as follows:
mpeg2
1920x1080
pal 50i
bitrate: 8 Mbps
format: ts
Issue: The recorded video is of low quality: choppy and blurry. I need advice what to change to get a smooth video suitable for TV.
Right now everything is done on the same SSD drive. Maybe I need a separate SSD for recording. Maybe I need to change vMix settings
to 1080 50i (right now it's 25p). I'm not sure about mpeg2-ts options either.
Any advice is welcome.
Witold
