Thom
#1 Posted : Monday, April 20, 2020 2:23:05 AM(UTC)
Thom
Hi Everyone!
I've used vMix before (although personally), however I uninstalled it because it was no longer needed and I needed the disk space. However, we're now going to use it at church, for live-streaming/mixing our services.
I'm having issues installing vMix (I purchased a new system between uses so there are no residual files).
When I run through the installer, when it gets to the bit where it runs all the DLL / AX files through regsvr32, I always have issues with vMixVideo.ax, with regsvr32 exiting with Error Code 0x3. (see screenshot)
I double check the directory to ensure that it's actually been extracted, it's there (see screenshot).
I then try to manually run the file through regsvr32, but it fails with the following error:
"The module "vMixVideo.ax" may not be compatible with the version of Windows that you're running. Check if the module is compatible with an x86 (32-bit) or x64 (64-bit) version of regsvr32.exe." (see screenshot)
I'm using Windows 10, Version 1909, Build 18363.778. (see screenshot
Some recent updates although I did have to replace my motherboard yesterday (from an MSI B360-based board) which is why there's a load of Driver Updates. (see screenshot)
My specs are:
  • CPU: Intel Core i5-9400F
  • RAM: 16GB DDR4-2666 Patriot Viper
  • Motherboard: Gigabyte Aorus H370 GAMING 3 WIFI (rev 1.0)
  • GPU: XFX Radeon RX 580 8GB GTS XXX Edition
  • Boot SSD: WD Blue 256 GB SATA M.2 SSD (C: Drive)
  • Drive 2: Seagate Barracuda 2TB 7200 RPM HDD
I've made sure that I'm using the latest download from the website, it is. I've tried installing about 8 times, all with the same outcome. Does anyone have any suggestions? Any support that can be provided will be greatly appreciated!
#2 Posted : Monday, April 20, 2020 2:40:11 AM(UTC)
Was thanked: 4668 time(s) in 1608 post(s)
See here:
https://www.vmix.com/kno...cording-and-blank-inputs
(Error message is different but it is the same issue)
Thom
#3 Posted : Monday, April 20, 2020 4:29:49 AM(UTC)
Thom
Originally Posted by: admin Go to Quoted Post
See here:
Thanks for getting back to me. Unfortunately though, it's still happening (I've installed both x86 and x64). Same error, same file. Any more ideas?
ask
#4 Posted : Monday, April 20, 2020 7:38:50 AM(UTC)
ask
Have you tried running the installer as Administrator?
Thom
#5 Posted : Tuesday, April 21, 2020 1:19:45 AM(UTC)
Thom
Hi Ask, indeed I have. However, I suspect the issue is not with how I'm running the installer, but with the compatibility between vMixVideo.ax and my operating system since it doesn't want to register even when I try registering it manually through the Administrator Command Prompt using regsvr32.
ask
#6 Posted : Tuesday, April 21, 2020 7:39:23 AM(UTC)
ask
OK. Something else is going on then. What I would do is re-image the PC. Do a complete install of win10, let all updates run. Then install vMix. I suspect you have another culprit stopping the installation.
Thom
#7 Posted : Thursday, April 23, 2020 2:35:34 PM(UTC)
Thom
OK, Thanks. I'll think about whether it's worth doing, and if I do then I'll get back to you soon.
Guest (7)
