Windsor
#1 Posted : Saturday, April 18, 2020 11:21:21 PM(UTC)
Windsor
Hi Thanks for the excellent software
I would like to use excel function to display multiple time
I have used google sheets with forumla =now()+1/24 but the datasource manager is not synchronisng the data every minute. Is there ability do it with in vmix?
Thank you
#2 Posted : Saturday, April 18, 2020 11:28:50 PM(UTC)
Was thanked: 991 time(s) in 823 post(s)
Using datasources works when the source is updated ( saved) regularly
there are 2 production clocks that you can create an input from ( with time offset)
scripting would also be an option if you need several different ones
Windsor
#3 Posted : Sunday, April 19, 2020 9:34:11 PM(UTC)
Windsor
@doggy thanks for the reply, but its not straight forward
I am looking for configurable time for GT Design with different time zones.
