GT
Word Time - multiple clock
Hi Thanks for the excellent software
I would like to use excel function to display multiple time I have used google sheets with forumla =now()+1/24 but the datasource manager is not synchronisng the data every minute. Is there ability do it with in vmix?
Thank you
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Using datasources works when the source is updated ( saved) regularly
there are 2 production clocks that you can create an input from ( with time offset)
scripting would also be an option if you need several different ones
@doggy thanks for the reply, but its not straight forward
I am looking for configurable time for GT Design with different time zones.
GT
