Bamboo
#1 Posted : Monday, April 13, 2020 1:23:24 PM(UTC)
Bamboo
I just upgraded my old 4 channel sound mixer to a Mackie 16 Channel ProFx with USB.
I downloaded a lot of software from Avid, Including Pro ToolS First, Waveform 11, and a few others. I'm able to manually mix my audio channels on the board, and use audio cables to route outputs to different audio input devices. I was hoping that since there is a USB connection that there would be some sort of connectivity to my PC that would be of benefit to me in my productions. I can't really find anything though.
Am I missing something? Any tips would be greatly appreciated.
Paul
andreypetr
#2 Posted : Tuesday, April 14, 2020 8:16:43 AM(UTC)
andreypetr
Install USB drivers, connect Mackie to your PC;
Add new Audio Input Device in vMIX, select your hardware mixer;
In vMIX's Audio mixer send sound from Mackie to M (master channel).
And you should have Main Stereo Mix from ProFX in your vMix production.
thanks 1 user thanked andreypetr for this useful post.
Bamboo on 4/15/2020(UTC)
Bamboo
#3 Posted : Wednesday, April 15, 2020 6:04:26 AM(UTC)
Bamboo
This worked! This should help tremendously. Thank you very much.
Paul
lyancey
#4 Posted : Thursday, May 13, 2021 11:39:34 AM(UTC)
lyancey
Thanks Andreypetr!
While the mixer is working for me with the ASIO driver, the latency is too much. When I change (lower) the buffer size in the Mackie Control Panel to reduce the latency, vMix automatically changes it back to 1024 samples when I add the audio input.
Is there a way to keep vMix from changing the ASIO buffer size to 1024 samples?
raugert
#5 Posted : Thursday, May 13, 2021 12:57:57 PM(UTC)
raugert
Canada
The minimum buffer size is set in vMix.
https://www.vmix.com/kno...sio-sources-high-in-vmix
Beppe
#6 Posted : Saturday, January 3, 2026 11:25:03 PM(UTC)
Beppe
Italy
Hi, I know this is an old question, but I haven't found any help online. I bought a Mackie ProFX6v3 and thought I'd use it with vMix to manage analog audio. But vMix doesn't recognize it in the audio extensions. Can anyone help me? Thanks.
