Joined: 2/19/2017(UTC) Posts: 31   Location: United States Thanks: 23 times Was thanked: 2 time(s) in 1 post(s)
I just upgraded my old 4 channel sound mixer to a Mackie 16 Channel ProFx with USB.
I downloaded a lot of software from Avid, Including Pro ToolS First, Waveform 11, and a few others. I'm able to manually mix my audio channels on the board, and use audio cables to route outputs to different audio input devices. I was hoping that since there is a USB connection that there would be some sort of connectivity to my PC that would be of benefit to me in my productions. I can't really find anything though.
Am I missing something? Any tips would be greatly appreciated.
Paul
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Install USB drivers, connect Mackie to your PC; Add new Audio Input Device in vMIX, select your hardware mixer; In vMIX's Audio mixer send sound from Mackie to M (master channel).
And you should have Main Stereo Mix from ProFX in your vMix production.
 1 user thanked andreypetr for this useful post.
This worked! This should help tremendously. Thank you very much.
Paul
Joined: 12/12/2020(UTC) Posts: 4  Location: Florida Was thanked: 2 time(s) in 1 post(s)
Thanks Andreypetr!
While the mixer is working for me with the ASIO driver, the latency is too much. When I change (lower) the buffer size in the Mackie Control Panel to reduce the latency, vMix automatically changes it back to 1024 samples when I add the audio input.
Is there a way to keep vMix from changing the ASIO buffer size to 1024 samples?
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Joined: 4/15/2020(UTC) Posts: 4  Location: Nocera Inferiore
Hi, I know this is an old question, but I haven't found any help online. I bought a Mackie ProFX6v3 and thought I'd use it with vMix to manage analog audio. But vMix doesn't recognize it in the audio extensions. Can anyone help me? Thanks.
