Ashqaraar
#1 Posted : Monday, December 16, 2013 11:10:13 AM(UTC)
Ashqaraar
I'm using two card Intensity Pro and Decklink sdi.
I just wanna know if i can use input decklink sdi for vmix 11.0.0.63 coz intensity pro is working correct.
My question is it possible to use Decklink sdi for input
thank you
asvtv
#2 Posted : Monday, December 23, 2013 5:30:34 PM(UTC)
asvtv
Groups:: Registered
We are using Deckling Quad (4 SDI Inputs) and it works like a charm.
You need to have all your setup (camera, converters, and inputs in VMIX) set to the same resolution (720p for us), otherwise you'll have a black screen !
Egriswold
#3 Posted : Monday, December 23, 2013 9:37:40 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
thank you
The short answer is Yes
Similar Topics
Intel NUC + Blackmagic DeckLink SDI Micro (Hardware Compatibility)
by Bartek-pl 3/13/2023 8:10:16 AM(UTC)
blackmagic decklink sdi capture cards (Feature Requests)
by francolombardi 4/27/2020 10:46:42 PM(UTC)
External Output on Decklink SDI not working - Solved (General Discussion)
by FrankLeggett 11/22/2019 10:52:18 PM(UTC)
by edumetz16 10/6/2018 1:14:49 AM(UTC)
Decklink SDI 4K? (Hardware Compatibility)
by vojam2001 4/24/2014 5:56:46 AM(UTC)
