Hardware Compatibility
Intel NUC + Blackmagic DeckLink SDI Micro
Hi, Intel NUC 12 PRO + Blackmagic DeckLink SDI Micro + VMIX BASIC HD Project VMIX: 1080P Input camera: Ursa PRO 1080P You can see jagged pixels in the image on sharp edges. http://www.webserv.pl/zlee.pngThe next picture shows a frame with GTX 1080 Ti + Decklink 8K Pro. The image is also brighter than on the Intel NUC. http://www.webserv.pl/dobrze.pngThe problem is visible only in VMIX. In OBS the image is correct. Any ideas?
