I'm using two card Intensity Pro and Decklink sdi.
I just wanna know if i can use input decklink sdi for vmix 11.0.0.63 coz intensity pro is working correct.
My question is it possible to use Decklink sdi for input
thank you
Thanks: 24 times Was thanked: 10 time(s) in 8 post(s)
We are using Deckling Quad (4 SDI Inputs) and it works like a charm. You need to have all your setup (camera, converters, and inputs in VMIX) set to the same resolution (720p for us), otherwise you'll have a black screen !
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Ashqaraar wrote:I'm using two card Intensity Pro and Decklink sdi.
thank you The short answer is Yes
