SRT
Larix Screencaster
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Anyone familiar with the Larix apps to/from vMix?
While Larix broadcaster and SLDP player work flawlessly with the Screencaster vMix seems to get stuck at the first image received
Edit:Input details show me a Frame rate of 90090.09p ???
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Screencaster is reporting a strange frame rate (90000fps!) which vMix does not support converting. I can potentially add some checking for crazy frame rates in a future update, it won't be perfectly smooth as the conversion will be wrong but will at least get some footage.
Martin vMix
I have no problems with the Larix Screencaster. No matter whether via the public Internet or local network. No freeze. I see a frame rate of 30p in vMix with a resolution of 1280x720. I had already described that here.
Originally Posted by: elvis55  I have no problems with the Larix Screencaster. No matter whether via the public Internet or local network. No freeze. I see a frame rate of 30p in vMix with a resolution of 1280x720. I had already described that here. Hi Elvis No issues with the other apps which provide a proper framerate etc , just the screencaster regardless of the vMix setup The ScreenCaster input as listener shows 1920x1080 H264 / 90090.09p
Try the Screencaster - Capture - Virtual screen reolution - with 720p. Adaptive bit rate - Ladder ascend. Have you also installed the latest update from Screemaster? Date 03/26/2020
Originally Posted by: elvis55  Try the Screencaster - Capture - Virtual screen reolution - with 720p. Adaptive bit rate - Ladder ascend. Have you also installed the latest update from Screemaster? Date 03/26/2020 Yes all been tried/done
Android LG V30 fully updated
I also tested it on a laptop with vMix. The same values as on the PC vMix. I'm using a Huawei Mate 10. I don't think it could be due to the LG processor because Huawei uses a different processor. Can't you test Screencaster on another smartphone? Otherwise I can unfortunately give more information than that it works for me without problems.
Edit: I have now tested the Screencaster app on a Huawei P20 lite smartphone. It also works optimally here.
Edit: Another question, do you have SRT with passphrase? I have not activated passphrase, I have not entered a password. I always tested it without a passphrase. This may also have an impact?
Latest update just released should now work with Screencaster (23.0.0.51)
Joined: 4/6/2019(UTC) Posts: 95  Location: Florida Thanks: 10 times Was thanked: 13 time(s) in 11 post(s)
Originally Posted by: admin  Latest update just released should now work with Screencaster (23.0.0.51) Thanks!!!!!!!! Will give it another try. Couldn't get the screencaster to work either when trying it out a few weeks ago. Thanks again!
SRT
Larix Screencaster
