#1 Posted : Thursday, April 2, 2020 5:19:40 PM(UTC)
Anyone familiar with the Larix apps to/from vMix?
While Larix broadcaster and SLDP player work flawlessly with the Screencaster vMix seems to get stuck at the first image received
Edit:Input details show me a Frame rate of 90090.09p ???
#2 Posted : Thursday, April 2, 2020 5:44:11 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Screencaster is reporting a strange frame rate (90000fps!) which vMix does not support converting.
I can potentially add some checking for crazy frame rates in a future update, it won't be perfectly smooth as the conversion will be wrong
but will at least get some footage.
doggy on 4/2/2020(UTC)
elvis55
#3 Posted : Thursday, April 2, 2020 7:17:27 PM(UTC)
elvis55
Switzerland
I have no problems with the Larix Screencaster. No matter whether via the public Internet or local network. No freeze. I see a frame rate of 30p in vMix with a resolution of 1280x720.
I had already described that here.
#4 Posted : Thursday, April 2, 2020 7:59:52 PM(UTC)
Hi Elvis
No issues with the other apps which provide a proper framerate etc , just the screencaster regardless of the vMix setup
The ScreenCaster input as listener shows 1920x1080 H264 / 90090.09p
elvis55
#5 Posted : Thursday, April 2, 2020 8:20:42 PM(UTC)
elvis55
Switzerland
Try the Screencaster - Capture - Virtual screen reolution - with 720p.
Adaptive bit rate - Ladder ascend.
Have you also installed the latest update from Screemaster? Date 03/26/2020
#6 Posted : Thursday, April 2, 2020 8:26:36 PM(UTC)
Yes all been tried/done
elvis55
#7 Posted : Thursday, April 2, 2020 8:36:59 PM(UTC)
elvis55
Switzerland
iPhone or Android ?
#8 Posted : Thursday, April 2, 2020 8:56:23 PM(UTC)
Android LG V30 fully updated
elvis55
#9 Posted : Thursday, April 2, 2020 9:12:29 PM(UTC)
elvis55
Switzerland
I also tested it on a laptop with vMix. The same values ​​as on the PC vMix.
I'm using a Huawei Mate 10. I don't think it could be due to the LG processor because Huawei uses a different processor. Can't you test Screencaster on another smartphone?
Otherwise I can unfortunately give more information than that it works for me without problems.
Edit:
I have now tested the Screencaster app on a Huawei P20 lite smartphone. It also works optimally here.
Edit:
Another question, do you have SRT with passphrase? I have not activated passphrase, I have not entered a password.
I always tested it without a passphrase. This may also have an impact?
#10 Posted : Wednesday, April 8, 2020 4:57:06 PM(UTC)
Latest update just released should now work with Screencaster
(23.0.0.51)
stigaard on 4/8/2020(UTC)
KnKproductions
#11 Posted : Friday, April 10, 2020 10:09:14 PM(UTC)
KnKproductions
(23.0.0.51)
Thanks!!!!!!!! Will give it another try. Couldn't get the screencaster to work either when trying it out a few weeks ago.
Thanks again!
Similar Topics
Larix Screencaster for Smartphone Screen (SRT)
by elvis55 2/5/2020 9:10:49 PM(UTC)
