ossewa
#1 Posted : Thursday, October 27, 2011 7:14:48 AM(UTC)
ossewa
Hi
First of all, thank you for a briiliant piece of software! I am evaluating it at the moment and I am very impressed.
Being a developer myself, I allways hope for some kind of interface into other applications, weather via API's, plug-ins etc.
The reason I am evaluating this software is to use it in church services.
We are currently using a program called "Lyrix" to display song lyrics, bible verses and notes on a projector. I need to show these in the video output from vMix. The text produced by lyrix is currently on a blue background - perfect for chroma key...
I tested the dektop capture functionality - but the response is a bit slow even at a higher frame rate. another way is to use the titles input but it would be a tedious job to create and display them for each song and verse.
Is there a way for me to develop a custom input or to get access to the titles to "Push" text to them from another Application?
Hope to hear from you soon, so I still have enough time to evaluate in my trial period.
Best regards,
Vermaak van Wyk
#2 Posted : Thursday, October 27, 2011 12:05:20 PM(UTC)
Have a look at the following developer information:
http://www.vmix.com.au/h...eveloperInformation.html
The DesktopCapture feature delay is only limited by the frame rate and response time of the capture machine.
At 5 FPS the delay is only 200 milliseconds which is usually ok for most applications, if it is slower than that I would suggest upgrading the capture machine with a faster CPU and/or graphics card.
davesuemcbride
#3 Posted : Saturday, December 14, 2013 3:38:06 AM(UTC)
davesuemcbride
A little late to throw this in, but if you're already Flash-familiar you can open an swf as an input and overlay it. Using transparency you can avoid any/all use of chroma keying while having lots of control.
David McBride
