Joined: 10/27/2011(UTC) Posts: 1 Location: South Africa
Hi
First of all, thank you for a briiliant piece of software! I am evaluating it at the moment and I am very impressed.
Being a developer myself, I allways hope for some kind of interface into other applications, weather via API's, plug-ins etc.
The reason I am evaluating this software is to use it in church services.
We are currently using a program called "Lyrix" to display song lyrics, bible verses and notes on a projector. I need to show these in the video output from vMix. The text produced by lyrix is currently on a blue background - perfect for chroma key...
I tested the dektop capture functionality - but the response is a bit slow even at a higher frame rate. another way is to use the titles input but it would be a tedious job to create and display them for each song and verse.
Is there a way for me to develop a custom input or to get access to the titles to "Push" text to them from another Application?
Hope to hear from you soon, so I still have enough time to evaluate in my trial period.
Best regards,
Vermaak van Wyk
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi, Have a look at the following developer information: http://www.vmix.com.au/h...eveloperInformation.htmlThe DesktopCapture feature delay is only limited by the frame rate and response time of the capture machine. At 5 FPS the delay is only 200 milliseconds which is usually ok for most applications, if it is slower than that I would suggest upgrading the capture machine with a faster CPU and/or graphics card. Regards, Martin vMix
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
A little late to throw this in, but if you're already Flash-familiar you can open an swf as an input and overlay it. Using transparency you can avoid any/all use of chroma keying while having lots of control.
Regards, David McBride
