jvphobic
#1 Posted : Sunday, February 23, 2020 3:11:53 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
I think I found a bug with the many input Multiviews.
Once I get to the 3rd layer of Multiviews, the stop showing up...
Input A & B are combine into a Multiview of C
Input C & D are combined into a Multiview of E
Input E is added to a new Multiview on F the A & B don't show up (or maybe it is C).
I created a quick explainer video in case I am not clear.
I am pretty sure that this used to work in older versions of Vmix.
Thanks a ton.
#2 Posted : Sunday, February 23, 2020 4:30:03 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Yes, this is by design for performance reasons. MultiView Layers will only render two levels deep.
TBacker
#3 Posted : Wednesday, February 26, 2020 12:29:29 AM(UTC)
TBacker
ONE more level would open a ton of doors that we've bumped up against. If there is any way you could optimize this code to do so it would mean the world. If it's a GPU resource issue, perhaps make it an option with a warning about minimum GPU / memory required.
I'm sure it gets exponentially more complex with each cascade, but there are a lot of complex shots required these days.
I tried working around this by passing one of our multiview source shots through a mix input and then put that mix input into a box. That worked for the video, but because of the audio limitations of the mix inputs, we would have to manually mix the audio for that source when the multi-box display is taken.
MartLeib
#4 Posted : Wednesday, February 26, 2020 6:02:29 AM(UTC)
MartLeib
Estonia
Maybe use overlay for the topmost elements? Automate it using triggers.
