Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Hi Joeboe,
Try downloading version 4.0.9 again. I may have uploaded an incompatible version with vMix22 for the first few downloads. You might have been one of them. :(
regards, Richard
 1 user thanked raugert for this useful post.
Yes, now it's working.....Thanks
I have a question...is there a way to open 2 windows with PB, and where I can clone a key and its function , copy and paste, to a new layout.....I ask this, because I made a preset, but wanted to make a new one, with the same buttons, but wanted to place them in a different layout, and I have 2 or 3 layers to some buttons, even in one instance, 5 layers...and having to do everything all over from scratch, i would like to just copy and paste....
You can't copy directly from one windows instance to another. The easiest way would be to Save your layout to another file and edit it accordingly.
Originally Posted by: raugert  You can't copy directly from one windows instance to another. The easiest way would be to Save your layout to another file and edit it accordingly. That is what I do, just thought there was another way.....does this work on Android tablets, or just windows and apple...
The Beta version currently works on iPad using the TestFlight app. I have an Android version that is still being tested. Hope to release it soon.
thanks....that would e great, as there are more Android tablets out there than iOS and windows....looking out for the release
Joined: 8/21/2019(UTC) Posts: 67   Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
Has the iPad beta been removed?
Starting today the app quits silently when opens. It no longer displays in TestFlight. Following the link at the top of the thread in TestFlight displays the error "this app is not looking for more beta testers".
It appears that the last Beta version was removed by the Apple connect site... I will investigate further...
thanks for the heads up, Richard
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Please android version for testing. Thanks
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
I'm having a little problem, but maybe it's wanted by you.
For the Tally to work, I have to put the number of the entry. But the problem is that the entry numbers change if I rearrange in vMix.
So I tried with the full name of the entries (example: 4c96cae8-da4c-4bca-96c0-44d9cb621100), so there is no problem in case of reorganization, but on the other hand the Tally no longer works.
With Google machine translation, I don't know if my question is clear enough.
I just understood, it is that it does not manage the accents in the name of the entries ... Is it possible to fix this for a future update? Originally Posted by: MickeyMJJ  Hello,
You should use the pulldown menu in the 'Input' field to select the Input you wish to control. That way the Name of the input is used, which allows you to rearrange the inputs in vMix.
Originally Posted by: raugert  You should use the pulldown menu in the 'Input' field to select the Input you wish to control. That way the Name of the input is used, which allows you to rearrange the inputs in vMix. Yes I did like this before. But there it no longer worked, so I said to myself that there may have been a bug on the latest versions. But in fact the problem appears on the name of the inputs where there is a character with an accent (and perhaps other special characters)
Hallo,
Then just give the entrance a different name. Bottom right on gear - name.
Update v4.0.11 https://cli.re/vMix-Panel-Builder-4.0.11fixed *common input feature to only recognize input names and not input numbers.. fixed selected index field not reloading index number fixed Zoom and Focus not stopping on button UP added hostname in "sync box" when syncing to tablet fixed french characters not responding correctly in Input Name fixed += value not working properly in Scripts
Rank:: Advanced Member
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
I edited a .csv preset and now I can only save a it as .tab, when I try to save it as .csv the preset is not added to my list of presets.
I am only working on a Windows PC.
How is that possible?
@Ronald555
When the file window opens up, select .csv in the "Save as Type" pulldown. If you normally create desktop templates (.csv) you should uncheck "Set Tablet Template" as default in the Panel Builder preferences. That will then select .csv type as your default when saving a file.
cheers, Richard
Thanks.
Set Tablet Template" as default was checked indeed, after unchecking it works OK again.
UPDATE: version 4.0.15 edit : ** fixing issue reported regarding file saving... new version upcoming **
added international characters support (cyrillic, french, etc.) fixed issue where if an audio input was offline, it would not update other fader and VU's properly added BusXSendToMaster shortcuts added BusXSolo shortcuts (note: Tally is not currently available in vMix API) added StreamingSetPassword shortcut added LowCPU option in Preferences (for computers with lower CPU capacity - VU accuracy will be limited) added Windows 64 bit version changed file extensions (Desktop files will now save with .vmpb extension. Tablet templates for (iPad and Android) will be saved with .vmpbx extensions). Older files (.CSV and .TAB) will still open, but will be saved with new extensions.
cheers, Richard
Note: Android and iPad versions will be available soon.
Thanks ...working nice as usual...just had a slight hiccup ...forgot to load my User icons before editing, and thought I would have to start all over....All I had to do was to reload them, and the old templates opened with my custom icons ...like the idea of low CPU, but because I am used to accurate readings, it will not work well for me, so I just leave everything as always......thanks for your updates, and will keep reporting if I find any bugs, but so far, its GREAT ...
