Joined: 2/2/2020(UTC) Posts: 2  Location: San Antonio Thanks: 1 times
Sorry I couldn't find this answer more easily - - But: We are considering setting up a multi-cam capability using DVI-D cables. Although we would have Multiple Camera inputs using DVI-D to HDMI converter cables The Audio input would all be the same and would NOT be coming through the Multi-Cam HDMI capture card (BlackMagic DeckLink Quad Recorder), rather the Audio Input will come from a PreSonus AudioBox over a USB connection. - Question - Can VMix be configured to select input from the AudioBox and apply that to whichever camera source is being streamed to the Internet ? - Thank You
Quote:Question - Can VMix be configured to select input from the AudioBox and apply that to whichever camera source Yes
On version 21 and having issues with audio stuttering during playback.,.listening live it is not a problem, but streaming on you tube it is an issue- any ideas?
Originally Posted by: AllenT  On version 21 and having issues with audio stuttering during playback.,.listening live it is not a problem, but streaming on you tube it is an issue- any ideas? Don't see what this has to do with this original post, a new separate one would have been more appropriate Upgrade your vMix version and if problem still persist give people a little but more detail about your equipment, setup , settings and all that could be relevant Just saying stuttering here but not there is not enough information for those that might be able to help
Doggy: Thank you very much :) :)
