Recommended Recording Settings for davinci resolve 16
Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Hi all What is the best (good) recording format for davinci resolve 16? I want to record around 50Mbps This is my guess at a good format?  Seams to be supported?  Thanks
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
I'd be inclined to use ProRes, which is what I've recorded from Blackmagic cameras/recorders and brought into Resolve.  RecordProRes.PNG (9kb) downloaded 0 time(s).
Thanks for that  It look like ProRes davinci resolve support is not as good for windows? (Kind of makes sense)  Apple ProRes 422 (HQ) has a crazy file size  Apple ProRes 422 (Proxy) is more manageable  Reference https://vmi.tv/training/useful-stuff/Prores_Codecs
You have been a member since:: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
Well, for professional post production, ProRes, DNxHD and XAVC-I codec is what everyone uses. Those bitrates are normal in these environments.
Does vMix support saving XAVC-I codec
I couldn't find it?
After some tests (Version 21) the only format (VC-3 or ProRes) that imports directly into davinci resolve 16 is: VC-3 MOV(Indexed)  For some reason it needs to be indexed?
