dgitygp
#1 Posted : Saturday, December 28, 2019 9:01:22 AM(UTC)
dgitygp
Argentina
I have vmix configured with a Blackmagic Decklink Duo 2 board. I was able to take inputs from that board. What is not working for me is to be able to send a video signal through one of the output ports. Those ports are connected to televisions.
Any particular questions you should consider?
regards
ask
#2 Posted : Saturday, December 28, 2019 10:08:54 AM(UTC)
ask
Please ensure you have setup the BM card using the Desktop Video app. Read this article https://www.vmix.com/kno...utput-on-a-decklink-card and the help files. https://www.vmix.com/hel...putwithIntensityand.html
sinc747 on 12/28/2019(UTC)
dgitygp
#3 Posted : Saturday, January 4, 2020 2:53:43 AM(UTC)
dgitygp
Argentina
Try to follow the steps.
connect with an SDI cable to a Blackmagic converter (MiniConverter SDI to HDMI 6G), but I have no output.
Can I try a Balckmagic application to see if it is configured correctly and is not a board problem?
I don't know what I can try.
dmwkr
#4 Posted : Tuesday, January 7, 2020 1:33:15 AM(UTC)
dmwkr
Just to make sure: Have you configured and started the External Output in vMix? Does vMix give any error message after starting the External Output?
emilt
#5 Posted : Tuesday, March 2, 2021 7:52:39 AM(UTC)
emilt
Norway
Seems the original poster isn't answering but I'll follow up as I have a similar problem to solve.
After setting up Decklink duo as the output device in external output I get the following error message when activating external output:
StartStopExternal
Selected Video Format is not supported by this device:
bmdModeHD1080p50
Error HRESULT E_FAIL is returned from a call to a COM component
I have translated this into English some the word might ber slightly different in English.
dmwkr
#6 Posted : Tuesday, March 2, 2021 9:00:27 AM(UTC)
dmwkr
Have you configured the output of the port in the Blackmagic Desktop Video application?
Also: Make sure you don't have the port that you configured as External Output also as an input in your vMix project.
xaver
#7 Posted : Tuesday, March 2, 2021 5:49:56 PM(UTC)
xaver
StartStopExternal
bmdModeHD1080p50
have you labeled the names of the port with the BMD Desktop Setup? If yes, the must need begin with a number and must have at least two signs
emilt
#8 Posted : Monday, March 8, 2021 1:31:57 AM(UTC)
emilt
Norway
I found the solution for my part.
Inputs ar prioritized before outputs. Meaning if you have set say SDI 1 as input, vmix will generate an error message if you try to use that port as an output at the same time.
So if you're still confused: If you are going to use a port as an output, make sure you haven't also added it as an input in vmix.
Magali
#9 Posted : Thursday, March 11, 2021 1:28:34 PM(UTC)
Magali
Thanks for the information, I will try to figure it out for more. Keep sharing such informative post keep suggesting such post.
visit here
Guest (4)
