Output with Blackmagic Decklink Duo2
I have vmix configured with a Blackmagic Decklink Duo 2 board. I was able to take inputs from that board. What is not working for me is to be able to send a video signal through one of the output ports. Those ports are connected to televisions. Any particular questions you should consider?
regards
 1 user thanked ask for this useful post.
Try to follow the steps. connect with an SDI cable to a Blackmagic converter (MiniConverter SDI to HDMI 6G), but I have no output. Can I try a Balckmagic application to see if it is configured correctly and is not a board problem? I don't know what I can try.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Just to make sure: Have you configured and started the External Output in vMix? Does vMix give any error message after starting the External Output?
Joined: 4/5/2020(UTC) Posts: 9  Location: Trondheim Thanks: 1 times
Seems the original poster isn't answering but I'll follow up as I have a similar problem to solve.
After setting up Decklink duo as the output device in external output I get the following error message when activating external output:
StartStopExternal Selected Video Format is not supported by this device: bmdModeHD1080p50 Error HRESULT E_FAIL is returned from a call to a COM component
I have translated this into English some the word might ber slightly different in English.
Have you configured the output of the port in the Blackmagic Desktop Video application?
Also: Make sure you don't have the port that you configured as External Output also as an input in your vMix project.
Originally Posted by: emilt  Seems the original poster isn't answering but I'll follow up as I have a similar problem to solve.
have you labeled the names of the port with the BMD Desktop Setup? If yes, the must need begin with a number and must have at least two signs
I found the solution for my part. Inputs ar prioritized before outputs. Meaning if you have set say SDI 1 as input, vmix will generate an error message if you try to use that port as an output at the same time.
So if you're still confused: If you are going to use a port as an output, make sure you haven't also added it as an input in vmix.
Joined: 3/11/2021(UTC) Posts: 1  Location: Ardellaborough
Originally Posted by: ask  Thanks for the information, I will try to figure it out for more. Keep sharing such informative post keep suggesting such post. visit here
