9 Pages«<45678>»
StepBackInTime_TV
#101 Posted : Thursday, November 7, 2019 2:32:45 AM(UTC)
StepBackInTime_TV
Was thanked: 17 time(s) in 14 post(s)
Data Sources:
There is a shortcut 'DataSouceSelectRow' - is there any way I can use this, or is there another API instruction, that can set the selected row for an individual input?
vMix 23 is amazing! Thank You!
Giles.
thanks 1 user thanked StepBackInTime_TV for this useful post.
avsoundguy on 11/7/2019(UTC)
#102 Posted : Thursday, November 7, 2019 2:42:06 AM(UTC)
Data Sources:
DataSouceSelectRow is not specific to v23 so imo question does not belong here.
if you mean by an individual input of a title that is linked to a datasource with multiple fields ( inputs) then the solution is to just havea copy of the same datasource for that particular field ( input) ?
StepBackInTime_TV
#103 Posted : Thursday, November 7, 2019 3:18:36 AM(UTC)
StepBackInTime_TV
Hi Doggy - thanks for your reply.
vMix 23 introduces a new feature which allows you to set each input to point to a different row of data in the data sources. What I'm trying to find out is if I can set these through the API.
* Added ability to select a Row for each text field now in Data Sources.
G.
Originally Posted by: doggy Go to Quoted Post
Data Sources:
#104 Posted : Thursday, November 7, 2019 3:34:07 AM(UTC)
AHA see what you mean , guess not (yet)
Mathijs
#105 Posted : Thursday, November 7, 2019 4:37:16 AM(UTC)
Mathijs
Can anyone else change the fullscreen output from the drop down menu? I still can't.
StepBackInTime_TV
#106 Posted : Thursday, November 7, 2019 10:58:40 AM(UTC)
StepBackInTime_TV
Has anything changed with GT Titles that would cause all the blank lines in my credit roll to be removed? The title editor still shows the gaps, but when I run the ticker (vertical scroll), the blank lines seem to be removed.
avsoundguy
#107 Posted : Thursday, November 7, 2019 11:01:59 AM(UTC)
avsoundguy
+1
JAIRODJ
#108 Posted : Saturday, November 9, 2019 4:58:11 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Regards, I've been testing vmix 23.0.22 I found these situations:
1.- When sending the new MIX entry to the air, it does not activate
the automatic reproduction of the selected videos, having to activate
them manually, this is inconvenient since vMix has the
option (automatically plays with the transition)
but with this new type of input it does not works.
2.- With respect to virtual PTZ, this option does
not work on videolist inputs, or in Photos (several photos),
it only works on inputs with unique elements
(this problem has been dragging since this function was added in vmix) ..
Attention - But if I activate virtual PTZ to the new MIX input ...
there it works with both PHOTOS and Videolist ...
which makes me think that it is possible that it also works with videolist and photos.
P.D. I think that virtual PTZ should work with all types of tickets,
sometimes and due to lack of time you cannot pre-configure options.
In addition the graphic interface of vmix is ​​being wasted,
there are spaces where you could show options necessary for
a quick configuration, you could list many but I trust the vmix team that can do better ...
first of all vMix is ​​still a great tool .
Excellent and congratulations vMix team.
#109 Posted : Saturday, November 9, 2019 1:30:11 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
With regards to the Mix input, it is manual control only by design as per the Restrictions noted in the documentation:
https://www.vmix.com/help23/Mix.html
Reason being there are numerous situations where an input could be both in one or more Mixes and also in the output
and a number of conflicts could occur as a result.
#110 Posted : Sunday, November 10, 2019 8:21:49 PM(UTC)
StepBackInTime_TV
#111 Posted : Tuesday, November 12, 2019 11:49:02 PM(UTC)
StepBackInTime_TV
I did some more testing with this last night.
I send my credit roll as a 'Text' type data source, which is used with a vertical scrolling GT Title.
In vMix 22 this worked perfectly.
In vMix 23, the gaps (CR+LF x 2) are removed. If I add a lot of CR+LFs, some space is made, but after a while, even these get eaten. I tried adding a space between the CR+LF with similar results.
It would be great if it is possible to restore the vMix 22 behavior with this. I've tried all sorts of non-visible characters to try and preserve the spacing, to no avail. Right now to make it work, I use down-arrow characters where the blank lines should be. The spacing is then preserved, but its not ideal.
Hope there is enough info here - please contact me if you need the GT title + data that I am using.
G.
stevespaw
#112 Posted : Wednesday, November 13, 2019 12:39:00 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Install Issue.
We have found almost every PC that we have upgraded to 23 needs to be rebooted after the install.
If we try to open last, or any previous project, we have an error that some long path does not exist. After a reboot everything works fine.
Steve
doa
#113 Posted : Wednesday, November 13, 2019 3:04:12 AM(UTC)
doa
Netherlands
Originally Posted by: stevespaw Go to Quoted Post
How do I Assign inputs to the new C-G busses?
They are showing up in the input matrix of the input (in the gear), but we have no button for the output on/off. We still just have MAB on each input in the mixer.
Annotation 2019-10-23 101448.png (19kb) downloaded 7 time(s).
Annotation 2019-10-23 100612.png (22kb) downloaded 2 time(s).
Am I missing something?
Can I see more than 2 channels of Audio on the Master Out? If I want to output to BMD SDI? Can I see meters for the 8 Channels in some way?
Steve
ashjmckenzie
#114 Posted : Wednesday, November 13, 2019 6:49:09 AM(UTC)
ashjmckenzie
New Zealand
Doa in your audio outputs you left all the OP buses router to channels 1+2 you need to increment them up
#115 Posted : Wednesday, November 13, 2019 12:56:20 PM(UTC)
EDIT: I can see it now, we'll get this fixed.
StepBackInTime_TV on 11/13/2019(UTC)
#116 Posted : Wednesday, November 13, 2019 6:07:31 PM(UTC)
23.0.0.23
http://cdn.vmix.com/download/vmix23preview.exe
* High Output Performance moved to advanced settings as many users were enabling it by accident on non-4K productions which was causing issues.
* shortTitle added to API XML to make it easier to use names on changing inputs such as the List
* Stinger1/2 shortcuts can now accept an optional Input parameter to switch preview to just prior to starting transition.
* Latest NDI 4.1 SDK included (This is still considered beta, if you notice any issues please let us know and we will pass on to NewTek)
* Fixed Facebook issue where created stream did not report as "ready to stream" in settings due to Facebook API changes.
* ActiveInput/PreviewInput shortcuts were applying incorrect input on Mix input.
* GT: Fixed white spaces disappearing on Ticker.
* GT: Fixed Page transitions not showing up in menu if TransitionIn/Out were blank.
thanks 5 users thanked admin for this useful post.
ask on 11/13/2019(UTC), StepBackInTime_TV on 11/13/2019(UTC), sinc747 on 11/14/2019(UTC), raugert on 11/15/2019(UTC), AndrewRed on 11/19/2019(UTC)
dabex
#117 Posted : Thursday, November 14, 2019 1:28:40 AM(UTC)
dabex
Italy
how can i ingest 8 audio channels with SRT? I receive a stream with 8 audio ch but I only see two of them.
Many thanks!
AndrewRed
#118 Posted : Tuesday, November 19, 2019 9:20:34 AM(UTC)
AndrewRed
Rank:: Member
Bug report for vMix Pro - 23.0.0.23 x64
The iCON midi controller becomes very glitchy with vMix 23. Something is making it disconnect and freeze up. When we go back and download vMix 22 the iCON midi controller works very stable. But something in 23 is causing the midi controller to loose connection and freeze up randomly.
Thanks so much for the great work you do and for all the great new features in vMix 23. The audio buses are so great and vMix pro has been so worth it for the extra calls!
you guys rule!
#119 Posted : Tuesday, November 19, 2019 12:28:50 PM(UTC)
Hi Andrew,
We have not made any controller changes in vMix 22, so there must be something about a new 23 feature
that is causing the iCON driver to fail.
Are you using any of the new features? Are your settings or presets different between versions?
I would suggest sending a support report and dropping us an email.
AndrewRed on 11/21/2019(UTC)
m-garanin
#120 Posted : Tuesday, November 19, 2019 5:03:00 PM(UTC)
m-garanin
About SRT: let me ask how I can send "streamid" in caller mode ?
SRT supports "streamid" (it very seems on "stream key" for rtmp) for access control.
https://github.com/Haivi...er/docs/AccessControl.md
For example FFmpeg supports it for caller:
ffmpeg ...... -I srt://192.168.1.210:9001?streamid=myStream123
So server can listen one port for many clients and do routing by "streamid".
// I known we can use "passphrase" for imitate "accesscontorl" but it's for encryption and means overhead.
Guest (13)
9 Pages«<45678>»
