Devs
#1 Posted : Wednesday, October 30, 2019 12:20:20 AM(UTC)
Devs
Poland
Hello. I have a problem with Local Desktop Capture. On first notebok there is only black screen but second machine is crashing and turns off when I add excel or program to scoreboard. Is someone knowwhere a problem is ?
Problem is visible on film which is on link below
#2 Posted : Wednesday, October 30, 2019 12:56:26 AM(UTC)
Devs
#3 Posted : Wednesday, October 30, 2019 1:16:04 AM(UTC)
Devs
Poland
Originally Posted by: doggy Go to Quoted Post
https://www.vmix.com/knowledgebase/article.aspx/42/blank-screen-when-using-desktop-capture
It was working 2 month ago on the same notebook with the same system windows 10. It stoped working 2 month ago.
Interesting is, that it's working exelent on my pc, where I have also windows 10 and also gtx 1060.
#4 Posted : Wednesday, October 30, 2019 1:32:54 AM(UTC)
in that case https://www.vmix.com/contact-us.aspx
but they will ask a little bit more info than just : "its not working", which might have helped here also
hellokitty
#5 Posted : Thursday, October 31, 2019 5:59:13 AM(UTC)
hellokitty
does your laptops have Dual GPU's? Intel and Nvidia? I have had a similar problem before, it is about witch gpu is bieng used for the application. Just use NDI Scan Converter and it should work, is one way to go. try that
